compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Sun Jan 15, 2012 8:21 pm
If you want to squeeze more out of it then yes, emanage,nistune, apexi etc would be beneficial. I really like the emanage because the features it has, pick your maf, injectors engine.... And you should be able to baby it down to the shop on it's base tune (if you upgraded stuff, if not than you can take it down to them and key them upgrade the maf, injectors etc before the dyno) where the e-manage is especially good is how I have my car setup. I have my regular computer base tuned for my setup and the e-manage to dial everything in that way if my battery ever dies (which it did once already) I can still drive my car on the base tune which is nice because you don't have to bring your laptop out to the car and resend it the tune you have saved right away. Where the emu really shines is the fact that its not sending your stock ecu a false signal to adjust the settings. It reads what is coming in, and simply adds or subtracts from your fuel our timing directly. (so much better than the safc!) Also a built in launch control with timing adjustment (pretty much anti lag) you can also control a vtec or nitrious solenoid. The list goes on. (you can also delete your maf) the choice is yours my friend. The most reliable setup is probably a rom tune but again is not really tuned for your specific vehicle.
