RB20 power steering using KA pump
smapdee2k
Hey guys. I've had my RB20-S13 for over a year with no p/s and it's about as fun as having fat Elvis sit on your face.
I've already tried the HICAS pump w/ the rear veins removed and rear outlet plugged and it didn't work out that well. After that I saw a write up about a KA24DE pump on an RB25 so I just bought one but it doesn't fit on the main mounting bracket (the one that bolts to the block) so I assume that the RB25 bracket must be a bit different.
Does anyone out there know any other options to get this thing on there or do I need an RB25 bracket (assuming it bolts to the 20 block)?
Nick51
Car: 90 240sx
yeah its about an inch to long right?
yeahh i tried that pump to but no deals
2nd on that if the 20 and 25 brackets are the same..
Carryl
for what its worth i used my sr powersteering pump on my rb..lil machining to the bracket... and some filing on the back of the sr pump.......had to use a custom belt though ...
smapdee2k
Yep, about an inch too long. It looks like even with some cutting and ghetto-rigging it probably still wouldn't work.
Thanks for the info on the SR pump Carryl. That's definitely a possibility for me if the 25 bracket doesn't work out.
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
This is for the 25 but you may be able to use it for the 20 too with some extra modification.
zer...69541
Bean2-240s
Car: 240sx s13 ka24de
240sx s14 Rb20det
I mounted a ka pump right up to my rb20 bracket but am missing 1 screw on the adjustment bracket, but it works
flartius
Car: 1996 - Nissan 180sx RB25DET
1996 - Nissan 240sx SE RB25DET - SOLD
Input is always appreciated, however, this post is ten years old! I'm sure OP has figured it out...
