rb20 power steering
ca18detizzle
Ok. Just installed the power steering. First, it turns really awesome. Second, there seems to be an abnormal screeching noise coming from the PS pulley, or around that area. Yes, I made sure there was fluid in there. ( any advice on what kind? DOT? ). It only happens when my car is warmed up and when on the gas. I made sure the pulley was on correctly. Any ideas?
Joe
nissans use automatic transmission fluid for power steering (dexron/mercon)
the screeching is probably caused from the belt not being tight enough
id flush it and run ATF asap tho.
ca18detizzle
ok, automatic transmission fluid for power steering. I didnt know that, I used some generic STP power steering sh*t. I should have known better. Looks like it's leaking as well. Puddle of Fluid each morning.
ca18detizzle
Here is a little video of the noise. It doesnt seem to be a screeching noise but it's rather a loud howl
OKCA18DET
aww i didnt hear any turbo noise
BoostFab
Car: S13cp, S13fb, S14z
using standard power steeing fluid on your can will ruin the steering rack-pinion. use only ATF for the power steering on your 240/rb. sqealing could cause by the belt slipping or bad power steering pump.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
ca18detizzle wrote:Here is a little video of the noise. It doesnt seem to be a screeching noise but it's rather a loud howl
Sounds like the pump. Did you change out the fluid yet?
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
Definately a pump growl. Change your fluids, you also may have a big air pocket. Fill it up and crank the wheel full turns side to side. That will clear out air.-Alex
OKCA18DET
Slo_240sx wrote:Definately a pump growl. Change your fluids, you also may have a big air pocket. Fill it up and crank the wheel full turns side to side. That will clear out air.-Alex
might wanna leave the cap off the filler container while you turn the wheel so the air can escape
