rb20 power steering help
pepegurr
Car: 89 coupe w/ rb20 swap - RIP but making a comeback
86 Porsche 944
92 FZR400 - Track Slut
95 240sx-se - Newest member of the family- DD
Ok guys i need a little help here, i just got in my new pressure side line for my RB20( thanks Djbutton ) . Now heres where the help comes in, I have NO clue where the lines go as it's been almost 2 years since i had power steering and there were no lines on my pump when i bought my motorset. I'm using the R32 hicas pump(already disabled the hicas) with my S13 rack and im not sure which side is the pressure side and which is the return side. I've already been searching but not much help has been found, mostly just obscure pics and not much else. Any help would be greatly appreciated , especially in the form of pics or possibly a diagram. Thanks guys.
shally2186
Car: S14.5
im using the SAME setup on my RB20 S13..
HP line of the front of the pump runs to the LEFT hole on the rack..
RIGHT hole on the rack comes up to the reservoir
reservoirs BOTTOM line goes to the pump
pepegurr
86 Porsche 944
Thanks for the help man, i really appreciate it. That was exactly what i was looking for.
RustspecS13
Car: '74 260z and '88 300zx turbo
What do you guys use for a feed line from the reservoir to the pump? The R32 pump and KA res are different sizes.
Can I use a reservoir from a different nissan? Or did you guys find adapters?
~Alex
pepegurr
86 Porsche 944
I used 5/8ths rubber line from NAPA. It fits snug on the reservoir and stretches just enough to slide right on the RB20 pump. I got mine all hooked up but now i've got a slight leak on the return fitting at the rack . I have to try to find a way to get it to stop leaking and ill be all set.
RustspecS13
What kind of rubber line? I was under the impression that heater hose eventually weeps PS/ATF fluid and that was the only hose you could buy from parts stores was heater hose and of course fuel line but I haven't seen that in big enough sizes.
~Alex
Carl H
it does weep/seep, trust my I have a nice greasy spot on my frame rail from it.best bet is to go to autozone or a hydraulic shop and get proper PS hose there, autozone is the ONLY place that seems to carry ps hose...even napa just looked at me like was a moron.
