rb20 owners..i need your help once again
240love
Car: 240
ok so i just wanted to ask...what gaugues are you guys using....or anyone using the r32 cluster...you cant use ka clusters can u?
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
Whats wrong with KA besides them being off track? Buy a tach and you'll be all set. And as long as you swaped in a KA Speed Sensor your readings will be correct. Otherwise you can use a R32 gauge cluster and modify it. OR you can just use the rpm tach and trim it to make it fit.
Anyone can correct me but from what I've read thats all I know. I'll be using stock KA gauge cluster maybe use a tach.
Sil240
Car: Nissan S13 "The One Cam Wonder"
I've heard you can just ""Turn"" the knob in the back of the cluster.But how accurate is that???????
I've also heard that you can run some resistors in there too.
Give it a SEARCH.. I'm not really sure.
I'm going to run a Defi tach, if I can ever get my tach signal back from ecu. POS!!!!
JerryRigRB240
Car: 1990 240SX Coupe with RB20DET swap
I'm using the 240's cluster with the R32 tach, trimmed to fit. I wanted to keep the 240 cluster cause I like HUD.
It looks pretty cool, as the R32 tach is a different color than the S13 one, so it stand out a little.
SeVa-S13
Car: '05 GTO 6spd
S13 cluster, R32 tach. It's not a perfect fit and a little light seeps through around the edges at night but it works alright.
240love
Car: 240
thanks guyss..helps alot...anyone have pics of the gauges they have...??
DJButton
Car: 2010 Nissan 240sx
I second the pics!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Ignore the phaser burn. This was my setup in my S13 R.I.P
240love
Car: 240
awssome...thanks ...anyone else?
