Rb20 oil leak
blues14
Car: 1995 Nissan 240SX GTS-t
So basically, my car has had a small oil leak for almost 9 months now. It is such a small oil leak that the oil level never goes down, but i see the spots under my car in the garage. Today, I got under the car to take a look and here is what I saw.
The back of the block is pretty much oil soaked. along with that, the bottom of the exhaust manifold is getting oil on it too
The car runs perfect, makes awesome power, and holds boost just fine. So where could this oil be coming from?? Can a headgaket leak this way?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
compression check that cylinder
NeRd_pUnK
Car: 1992 Lexus SC300
My guess would be that banjo bolt. I would clean the area with some brake parts cleaner or carb cleaner and run it around the block and see if you get any leak.
Carl H
valve cover gaskets fo sho.same thing happened to my car, and still is leaking even tho they are new gaskets...
redtop240
Car: 92 240 RB20 Coupe
Oh man I have the same problem. Carl, it's just probably a valve cover or gasket leak? It's always just a little bit every night.
Carl H
most likely valve cover, if your hg was leaking like that you'd know due to lost fluids.
blues14
i thought it was the valvecover gasket at first too. I replaced it but i didnt change the semi circle gasket cuz i didnt know it was there at first. maybe i will cake some goopy gasket stuff back there and hope it stops. The car put down 320whp with the leak and all plugs look good, so i don't think its causing a problem with the cylinder.
mello88
Car: s13
Mine did the same thing; It was the half moon part of the valve cover gasket. I haven't fixed it yet, guess I need to re-RTV it...
GL
nerd_punk wrote:My guess would be that banjo bolt.
FYI that banjo bolt is for coolant, not oil.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
There is a banjo fitting on the top of the turbo for oil.
Also check the oil feed line, make sure its not leaking, a friend of mine had leaking coolant feed lines on his SR with tiny pinhole sized leaks around the end of the line the banjo fitting slides in.
blues14
nah, my lines are ghetto, but not leaking.
d356bud
Car: 1990 240sx w/ RB25DET
I had that exact same problem, I replaced the valve cover gasket and it fixed it
