RB20 oil feed for aftermarket Turbo
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Ok guys let me know if there is a problem with this. I reused the factory banjo bolt and got a line made to feed to my new turbo. A local place out here in Cali called Banaco hoses and Fittings made it for me. Total cost was $32 after taxes.
Fits like a glove, I did this same setup on my DSM when I switch from the factory turbo to a T3/T4E. factory oil feed banjo to the garret oil feed and never had a problem with it.
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
As long as it doesnt leak i dont see a problem with it
BoostFab
Car: S13cp, S13fb, S14z
looks fine to me. use new copper gasket at the block side.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
What is the new turbo? Remember there is a restriction built into the stock bolt... also check to see what the new turbo specs for a bolt thread height and where the hole is spec'd
Yellow4g63
It's a SC61 turbo. I talked to a few others and they haven't reported any problems doing it the way I have done it..... yet lol.
BoostFab
restriction is good, too much oil pressure to the turbo = blown rear seal.
another reason why they made these for standard bearing (ball bearing turbo has a built in restrictor):
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
where to find those -4an resistors to bring them to a -3an
