rb20 not starting
bigfootap
Car: 1991 240sx coupe
I'm pretty much done with my rb20det swap into my 240sx but I cant get the car to turn over.
If I prime the fuel pump a bunch of times or put starting fluid in it it will start for a couple seconds
but thats all I can get. Anyone know anything that it could be?
rb25det250sx
Car: '96 Nissan 240SX RB25DET powered!!!
make sure you dont have the fuel lines switched up. people get confused and hook them up the wrong way. i;ve done it once.
Dirty Dee
Car: 1989 240sx
double check the timing. If you give it some gas to hold it at a higher rpm, does it stay on for longer, or does it bog out?
definitely check the fuel line routing
bigfootap
I made sure the fuel lines were going the right direction and all that stuff.
However i think the injectors arent pulsing when I crank the car.
I checked the wiring going to the injectors and its all getting 12 volts.
Could the injectors be bad?
rb25det250sx
check cas.
evildave32
Car: 91 240sx rb20det
I had to wire a relay to the fuel pump to run at 12v constant because mine kept flooding. Has worked fine ever since.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
power to the 2 relays near the ecu?
bigfootap
Yeah, everything is getting power. how do I check the CAS and why would it keep the injectors from firing?
s14danny
if all coils are not firing then try ignitor?
bigfootap
the coils and ignitor are fine. its the injectors that arent firing. it gets spark just not getting fuel.
RustspecS13
Car: '74 260z and '88 300zx turbo
Are the injectors getting power?
My swap had 2 problems- the injectors weren't firing, and the #1 coil kept burning up.
The injectors were the relay wasn't getting a signal to turn on, so i tied it into the other relay, and I ran new wires for the #1 coil. Problems solved.
~Alex
bigfootap
yeah each injector is getting power.
bigfootap
I know that before I got the engine it sat for a long time. I'm sure that could cause some sort of problems and I was hoping it wouldnt have a problem. Is there any way to check the CAS and injectors?
gandza
Car: s13 240sx rb20det
pull the cas off and spin it with your hand, if u hear the injectors ticking u should be fine, thats how i checked mine, alos rustspecS13, i had the same problem i burnt a coil pack the other day when i got mine started, u think i should run new wires? and were do you get your coils from?
bigfootap
And I should have the car on when I do it right?
