hi,
new to the fourm here so sorry for the new post ive been looking for the answers i need but no luck.
anyways i have a 89 240sx HB with a rb20det swap, ive done it all myself bought new pre made harnesses from wiring specialties so my wiring shouldnt be an issue. the problem im having as title says i have no spark! ive replaced the igniter with a brand new j30, repined the plugs following a cupple pples directions and pictures on here and i doubble check it even tripple checked it. still no spark!
i have fuel and made sure i did just so everyone knows thats not it. i pulled the cas out spun it and the injecters click, the fuel pump kickes on/ primes up, but no spark. i have 12v to all coils and i do have a pulse when i spin the cas so i have no idea why theres no spark. i checked plug gap and also plugs are wet so i know i have fuel. is it possible all my coil packs are junk or even the ECU? before putting the motor in the car i tried to start it out of the car it did pop over and ran for a few seconds on starting fluid i didnt have a maf at the time and wasnt it hooked to a fuel pump/tank so i think that why all it did was barely run. ive been working on cars for over 18 years but im new to the rb motors so any advice would be great! ASLO more info car does crank over and everything else i have hooked up works fine..
thanks
jesse
