RB20 needs a turbo!
atticus
I am sure this topic has been covered before, but I am in need of an internally gated turbo that will bolt to my stock manifold. I have heard that the Z31 turbo will work. Is this a straight T3? Will I need to modify anything to do this? Thanks for all your help guys.
lmnhed
Car: 92' S13 coupe
OK, I have a rebuilt Z31 T3 turbo on my RB20 as we speak. Its not a direct bolt-on, but it isn't bad if you or someone you know can weld. Early Z31 turbos were t3(84-87), later ones were t25(88-90). I am not for sure on those years. Heres what I did:
-Make a new oil feed line, I just cut the banjo fitting off of the stock line and then weld on a 4-an fitting and run a new line to the turbo that way.-The stock water lines will bolt up to the Z turbo with a little prying on them.-Use the oil return tube off of your rb turbo-You'll have to chop the flange off of the Z31 O2 housing, as that has wastegate flapper in it. Then weld on another pipe. I just got a 3" mandrel u bend, O2 sensor bung. and a 3-bolt 3" flange from the local hot-rod shop , then I just cut and welded it all together. -I also had to grind down the compressor outlet pipe that bolts to the turbo because the rb uses a 3-bolt set-up where as the Z just uses a coupler and a clamp. It was a pain to grind the 3-bolt flange into a circle, and I messed up my grinder since it wasn't meant to grind aluminum, if I had planned ahead I would have just fabbed up a new pipe.
That all I can think of right now.
240+civic=pimp
Car: s13/rb20det, 2002 WRX, 1994 Yamaha fzr600
I GOT A T3/T4 GARRETT BRAND NEW .63AR $400
SeVa-S13
Car: '05 GTO 6spd
What trim?
