Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Fri Jan 02, 2004 2:07 pm
My swap is still going. My semester started back up, and I got too busy to finish it right away. So now the details are dragging.
But the engine is in. I used the R32 x-member and transmission mount with no modifications. (No, you do not need to turn the transmission mount around.) As expected, the shifter sits about 1/2" forward, which is no big deal. I have pics showing the shifter in 3rd gear vs. 4th gear to show that there is plenty of room. The driveshaft is of course in the same place as with the KA. The bottom of the oil pan sits at the same height as the KA's pan.
Most people have clearance issues with the steering shaft hitting the O2 sensor housing (turbo outlet), but mine misses by 1/8 to 1/4". Since the engine torques counter-clockwise (engine turns clockwise from the front), there should not be any binding under load. However, when the steering rack is under load, there could be a problem. No worries, tho, since I had already planned to make a custom 3" pipe.
There is actually quite a bit of room in the engine bay, but it would not be possible to move the engine back more than maybe 1/2". So if anyone says they can sell you mounts that move the engine back farther than that, don't believe them. On the front side, there is not much room for fans, although I have seen at least 1 car with electric puller fans mounted. I know my PermaCool 12" will definitely not fit as a puller. There is only maybe 2.5" from the radiator to the pulleys.
I did all of the wiring while I had the engine out, so that's finished. Still need to get a custom PS line, hook up the radiator, fuel, and heater hoses. Find some way to make the throttle cable bracket work. Hook up intake piping and intercooler. And put the N1 dual on. Install the Walbro 255.
The details.... plus, this car sat up for a while and the brake rotors have too much rust. I need to go get them turned or wire brush them or something before I do something stupid like go fast with bad brakes.
