skillzilla »
https://forums.nicoclub.com/skillzilla-u17041.html
Sun Jul 24, 2005 7:27 am
Hey, I have an Inline-5 now, and its driving me crazy. My car runs incredibly rich, even after I tried running the stock fuel pump nstead of the GT-R unit. Also its sputtering and bogging pretty much all the time, a DEFINITE miss on one cylinder.
OK, what Ive done so far is pull all the plugs and coils (all the pugs were black as hell, prolly from running super freakin rich all the time), checked the injectors for leaks and checked the ecu for codes.
So I cleaned the plugs really well and tested em all, they all spark fine. Also tested all the coils and they are sparking fine. Also didnt notice any injector leaks or smell gas with the fuel pump on and the motor not running. The ECU threw a weird code (#21, no ignition signal to the ECU) but once I reset the ECU it showed 55.
One last thing, the car runs awesome for about 20 minutes in the morning, seems to only mess up when its at normal Op. Temp.
SOOOOO, what are my options? Could it be a bad sensor which is putting me in limp mode (Im thinkin coolant temp or something)? What about a timing issue? I never really timed the motor and I dont have a timing light so Id have to get one and do that, but if it only happens when its hot would that be the case or what?
Also, what about bad wiring somewhere? Whats up with that code #21, anyone diagnosed problems from that before?
Thanks in advance for your help.
