When you put the coils packs on did you throw new plugs in?AngelusRB20Freak wrote:I had been having a pretty nasty misfire problem for a while, just recently, I checked the coil packs, and replaced two faulty ones with Q45 coils. After that, all of the coils work perfectly, and the car is running all but perfectly. At low revs, it runs evenly, if you take it up slowly, at high revs, it runs even, the only problem is when you go full throttle, then around 8 lbs of boost it starts misfiring in a pretty ugly manner, I mean it pushes through but I'm losing a ton of power, and I'm really worried. Anyone have any ideas?
Its definately possible under load the coil creates a lot more heat and over time that heat will break the electronic parts down unfortunatly with the rb20 were dealing with coils that could be over 15 years old. When you replaced the other coils did it make a difference? Also plugs would have been a good idea to replace mainly because you had a misfire so they are getting coated with gas that will in turn foul them out. The first signs of a plug fouling out is a misfire underload because its easier for the spark to jump somewhere other than it suppose to than it is to jump across a gas covered electrode tip. Hope this helpsAngelusRB20Freak wrote:By now, Ive changed 4 of the coils, 1&2 are still old. Is it possible that the coils are crapping out only under load, and during idle they work fine? Can that happen? Cause it kinda feels like a coil, but what do I know.
Wow!! i thought i was the only person that did the rewire for the coils lol But like you said coils are a plus and correct gap is crucial if its just a little to wide under boost it blows out the spark and if your running more boost than stock tighten up the gap a little. Def sounds like a coil problem here but why waste your time just putting coils in when you should throw plugs in too so you know they aren't fouled from the misfiringmatafied wrote:Just to add this in, and not saying that this is or isn’t the problem. I have found on my rbs that the factory 12v supply (white wire ) was not sufficient enough to supply the current needed to fire all the coil packs at high revs. I changed my coils; I changed my plugs, and then converted my ignition. still no beans, And the end result was using the factory 12v (white wire) to switch a relay which carried the larger gauge wire coming strait from the battery 12v source fixed everything! and yes changing the plugs after its been misfiring is only common sense, i cant tell you how many sets of plugs i went through! but the set of AC Delcos i have in now are by far the best yet, and they had 70K on them when i pulled them out of a 06 malibu havent let me down to date!!
