240wootie »
https://forums.nicoclub.com/240wootie-u35632.html
Sat Sep 15, 2007 7:31 am
the MAF that came with my rb20 was shot. it wouldnt start with the MAF plugged in so i bought an N60 and wired it up. it now starts with the N60 plugged in but it wont rev at all. it starts and then makes a popping noise like the blow off valve. i wired the two wires with the plastic/wire casing together, matching like colors, and then wired the black/silver dots together and the white/silver dots together. all the colors match, but it still wont run right. i researched this for about two hours and found that it usually is caused by a boost leak, faulty MAF, or fuel pressure. i am running a 255 fuel pump, and i know it is working and i cant find a boost leak. any ideas?
