Okay, so the short is sorted. Reset the ECU and checked for codes, showed 55, all good.
I found a thread online about a similar problem, and the solution ended up being that the aftermarket air filter caused strange airflow/turbulence, causing the MAF to read improperly. Thinking it was a long shot, but worth a try, I took off my aftermarket air filter/intake thing. Then, I put my KA air filter up to it. I couldn't make it fit in there quite right, but I got it hooked up well enough.
Imagine my surprise when the A/F went to around 13~15. I'm thinking the MAF is hooked up too close to the turbo and/or too close to this big aftermarket intake/filter thing, causing turbulent air and an incorrect measurement by the MAF. As you can hopefully see from this pic, there's a small bend out of the turbo, then the MAF, then the filter. I'm thinking that is the problem.
Is this a decent possibility. It certainly seems like it to me. Anyone have a similar experience?
