Liquidus »
https://forums.nicoclub.com/liquidus-u11556.html
Sat Sep 24, 2011 10:07 am
@compatfean. If you read my post, you saw that I tested the MAF voltage and boost leak. TPS voltage was also checked on my and is fine, and I don't think that would cause lean conditions, but idk, I'm not a master mechanic and don't have a bunch of tools, but I love cars and am trying to learn as I go. Your post isn't really helpful in any way. Do you just copy and paste that into every post asking for help with an engine swap? Useless.
To the more helpful people:
Okay, so I've done some more work. From inspection it seems like the injectors are actually stock, despite the fact that I was lead to believe they were much larger. It was kinda dumb for me to not check this earlier.
I've searched for the number on the injector but came up with zero results. They have a red ring facing out and say 5L31 2108, with a little nissan symbol outline in between the 5L31 and the 2180. If anyone can confirm what injectors these are I would greatly appreciate it.
I also got a fuel pressure tester and am seeing around 40psi, so it's not the fuel pump/lines.
Based on this info here is what I am thinking:
1. The injectors are wired wrong? The fact that it idles so well with no MAF, and that by adding fuel with the SAFC with the MAF on I can get the A/F to 15:1, seems to indicate that this isn't true, but I'm not sure on this though, please let me know.
2. This ECU has fuel maps for larger injectors? If these are in fact stock RB20DET stock injectors, maybe the ECU has fuel maps for larger ones, causing the lean A/F. Unfortunately, I have no idea how to test for this.
3. The injectors are N/A RB or KA injectors? Since I haven't been able to confirm the number on the injectors, and that I think that this engine used to have larger injectors, is it possible the injectors were replaced by ones that are too small? Not sure here either.
Based on this info, what do you guys think. If you can help me test/rule out any of these, I would really appreciate it.
Thanks,
Rob
