rb20 knock HELP!!!!!!!!!
azrbs13
Car: 1992 s13 hatch rb20 5 speed
i have an s13 which i swapped an rb20 into i finally got it started and along with that sexy exhaust note that came screaming out of the dump pipe i was fortunate enough to blessed with a knock... :mad: ... the knocking doesn't seem to be accompanied by any rattling. what i mean is when you hear the knock it sounds like whatever is knocking is pretty solid (no indication of loose or broken pieces flopping around) if that doesn't make sense just ignore it. also when its trying to turn over there doesn't seem to be any knocking
basically im trying to find out if the knocking is a rod knock or if its an issue with a lifter(s). the reason i suggest a lifter issue is because I've done some searching and on YouTube Ive come across a couple videos of other RBs making the same noise and one of them the problem was air got trapped in a lifter and it caused the same noise (loud consisting knocking)
here is a link to my my car http://www.youtube.com/watch?v=pRXMn8zJpZU (caution it will get loud)
and here is a link to the RB25 http://www.youtube.com/watch?v=QrlJMbuTKJg
please help me figure out what the problem is so i can finally get my baby in proper working order
p.s. what could the cause of the idle problem be???? (watch my video and you'll know what i mean)
any help will be greatly appreciated!!!!! :dblthumb:
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Sounds like rod knock but could be wrong your no exhaust isn't helping.
azrbs13
ya i realized that after i posted the video to YouTube the video seemed a little cleaner when i recorded. im going to put on the exhaust this weekend and post a better video
thanks for replying
Gabes13
Car: rb20det s13
Its hard to tell from the short and unstable idle. Finish putting the car together and run it for a while. When I changed some valves months ago i didn't soak my lifters in oil and I had a lot of chatter on my first start up. Do you have an oil pressure gauge?
RRRRB
Car: 98 RB powered S14
im gonna say that sounds like a lifter issue to me... rod knock is much deeper sounding and not as frequent as what you had going on... get some exhuast hooked up and let the engine run a while see if it goes away..
azrbs13
Gabes13 wrote:Its hard to tell from the short and unstable idle. Finish putting the car together and run it for a while. When I changed some valves months ago i didn't soak my lifters in oil and I had a lot of chatter on my first start up. Do you have an oil pressure gauge?
no oil pressure gauge yet im running a little short on funds right now.
azrbs13
RRRRB wrote:im gonna say that sounds like a lifter issue to me... rod knock is much deeper sounding and not as frequent as what you had going on... get some exhuast hooked up and let the engine run a while see if it goes away..
thats the plan for this weekend so hopefully by Sunday i can have another video up
Cjmartz2k
Car: Hunting for a '89 GTR now
As stated, take a video with the exhaust hooked up, but it sounds like a spun bearing to me.
TheRBguy
Car: S13 240sx Rb25det swapped
My rb25 has lifter tick and it is NO WHERE near that loud, i would say you have a spun bearing, definitely dont run it till it throws a rod through the block. Get a long screw driver and put it against the valve cover and block and put it up to your ear and see where you can hear the noise through the screwdriver at.
azrbs13
TheRBguy wrote:My rb25 has lifter tick and it is NO WHERE near that loud, i would say you have a spun bearing, definitely dont run it till it throws a rod through the block. Get a long screw driver and put it against the valve cover and block and put it up to your ear and see where you can hear the noise through the screwdriver at.
ya i think i was just in denial about the knock :chuckle:
im pretty sure the knock is coming from the 1st 3 cylinders im leaning more towards the number 1 cylinder but we will see
im going to try and find out what i can, possibly on Thursday
i was hoping to know by now whats knocking but i ended up having to spend the weekend fixing a different car. :mad:
azrbs13
i have finally confirmed the the knock was indeed a rod knock :frown:
the rod bearing on #2 was reduced down to a pile of dust
im still dumfounded as to how the crank was not completely f*** on this :confused:
any recommendations on what bearings i should put in
Yellow4g63
You need to get the crank checked out and balanced. Slapping in a new bearing won't help. If you just want to drive then buy another short block it would be cheaper than a rebuild.
