FerrariTruck »
https://forums.nicoclub.com/ferraritruck-u144533.html
Tue Dec 29, 2009 3:13 pm
Well finally got around to sealing all the intake leaks and went adjusted the TPS from .38v to .50v...
Also got an adapter and put a filter on the MAF.
After doing so the god damn car finally starts easily and actually rev's up with the throttle! Finally heard the blow off whoosh!!!! However, it seems like i have coolant leak, coming from the water pump area..ugh,.
Also the mfkr is smokin good, so rich my eyes get teary.
Also, the damn fans didnt come on, I used the ka connector for the fans but im guessing now the pcm aint gonna make those turn on. So i gotta put in a temp sensor and use that to trigger a relay.
just when your so close, your still far away
