rb20 issues
grmreapr
Car: 89 rps13, 02 mazda protege
So I just dropped in a rb20 while I rebuild my sr but it's giving me some problems. It does not want to idle for anything I had to tighten my throttle cable so it will idle. Also it hesitates I push on the gas a little bit and and starts to buck a little bit but if I depress the pedal it goes away it builds boost fine and everything else seems to be fine I haven't had time to grab my friends boost leak tester but all my couplers seem to be fine I don't know much about rb's so maybe im missing something. If you need to know its completley stock running a front mount and that's it.
Romeo_rus
Car: zenki RB25DET - SOLD, zenki SE ka24de - wrecked, zenki - sold, GOLD ZENKI - WILL LIVE FOREVA
TPS?
dvswakesk8420
Car: nissan s13 rb20det
hows the fuel pump?
grmreapr
fuel pump is fine its a 255 walbro as for tps everything checks out ok we where thinking I need an intake manifold gasket could that cause my issues??
rb24021
check it inside and outside for leaks..even the smallest leak can cause those types of problems...trust me i know lol.
grmreapr
for those wondering it was a bad maf
GTRs13
Car: 89' S13 Coupe AWD RB20DET
It ALWAYS is, can we get a sticky so we can prohibit threads like this?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Make one of those Boost leak checkers cost me $12.00 at home depot.
Mine's not stock but I found that I had leaks at the throttle body and from my IACV.Def check it, would let you know if your ITM gasket is bad.
