DriftX »
https://forums.nicoclub.com/driftx-u61933.html
Sun Nov 18, 2007 11:20 am
I still think I have a set of junk coilpacks, but here's my problem:
The car starts up smooth, drives smooth but once i get to about 5k rpms, the car will pull just o.k., not like it should, it will sputter, pull, sputter, pull hard.. then it's at redline.
Well, before this, the car would hit about 4k rpm and just buck and not climb any more, so I taped the coil pack boots and braket, and it helped a ton, but it didn't fix my problem.
So I bought another set of coilpacks off a good running engine - put them in.. it helped clear it up some, but it still pops out the exhaust at higher rpm (unburned fuel - no spark - hot exhaust) yaddi yadda..
So is it possible I got another set of junk coilpacks, or should I look elsewhere?
I'm running the stock r32 skyline pump, so it's matched for the engine and should be at correct fuel pressure - not rich like with walbro
holds 18 on vaccum gauge
stock tune, front mount, pod filter, full 3in exhaust - so it shouldn't throw the stock tune off with just those parts.
I'm lost - what steps should I take to test components and get this thing running 100%?
Hey Carl, when can I come over and let you wave your magic wand over this damn thing and make it run good haha
