240sxautox »
https://forums.nicoclub.com/240sxautox-u49983.html
Thu Sep 20, 2007 8:15 am
1993 Nissan 240sx SE coupe
Intro: A little information about me. I'm 19, I live in Kennesaw, Georgia. Im about 30 miles north of Atlanta. I previously had a volvo 850 t-5 (I miss it) and I figured I'd post some pictures/videos of the RB finally on the specific forum so you guys can give me some feedback on the setup. Feel free to give me any advice- even in the form of criticism, I'm open to it all, and always want to learn more about the motor/car/different setups.
An Update on the motor status right now- The headgasket began to blow as soon as I switched from 4psi to 11.6psi- as I expected. I ordered the new cometic headgasket and ARP studs the same day (well, weekend) that I installed my new spring in my wastegate. I figured it would happen, might as well build it stronger! I have one main question: What kind of boost levels could anyone suggest with my setup on a new cometic headgasket/studs/timing belt/intake mani gaskets/etc ? I've got an 11.6psi spring, and a manual boost controller and a 4psi spring- so with that combination of parts I'm sure I can find a nice boost level I should run. Any suggestions? Thanks.
Drivetrain/Upgrades/ETC:-RB20DET-GT3255E Precision Performance Turbo-440cc drop-in injectors-Walbro 255lph fuel pump-Fuel pressure regulator-Z32 MAFS (changed over to MAP system now)-Greddy E-manage Ultimate (boost/injector sensors/MAP)-Dual Pass FMIC (by Tophat)-Greddy BOV-Stage 3 clutch, can't remember the name at the moment-TiAL 38mm External Wastegate with screamer pipe (soon to be routed out the side of the car)-11.6psi spring in the wastegate, also have a 4psi spring, and a manual boost controller (which isn't hooked up at the moment)-NGK AFX Wideband-Autometer Gauges (boost/oil pressure/will buy a water temp soon)-3" Apex'i N1 exhaust with resonator and all (I love the fact that it keeps it to a quiet rumble at idle, but that all goes to **** when the wastegate opens- wakes up the neighbors thats for sure)-New intake manifold gaskets-New timing belt/rollers/etc.-New Cometic headgasket and ARP studs on the way- Head will be getting decked when we replace the headgasket.-Nardi steering wheel, and Redline Goods shift boot/e-brake Boot (NICE products by the way, check out Redline Goods in the advertisers specials on NICO!)-R33 Skyline GTS-T seats (making uber custom brackets for them... on the floor basically...they're so comfortable and such a good deal I couldn't pass them up)
VIDEO:
Pictures: (I'm teaching myself how to weld, so go easy on me if they suck. That's part of the first design of a bracket i was making- but it still sat up too high for me. I'm 6'6")
(R32 GT-R steering wheel, now replaced by a nardi- although the GT-R wheel I am keeping because it is really thick, and easy to hold onto- I want to find a good wheel wrap for it so I can use it)
I'll take some more recent photos/video soon. Especially while I'm redoing the headgasket and finishing up the seat brackets.
Let me know what you think! Also, let me know any ideas for boost levels, etc.
