squbafreak15 wrote:ok so ive had numerous problems with this swap. bent valves wiring bad coil packs. kept blowing ignitor so paid to have it wired a 2ndtime. now it finaly has spark. and fuel. it wont start. it fired once. and then nothing. it seems like it keeps flooding out so i will take the plugs out and let it dry. nothing. ive tryd starter fluid i cant figure it out? i know there are a few threads like this but they dont say what solved the problem. can someone please help me im really frustraded with this swap and just need it running.
Bro I am in the same boat as you. Ours fired up on its own the first few times. Then all of a sudden it wouldnt start anymore on its own. It needed starting fluid. Im wondering if CAS timing could be off? But why would it start and run on its own before and not now? Also if I use starting fluid to start her up she fires right up and then idles normal.
