SR24DET »
https://forums.nicoclub.com/sr24det-u65780.html
Sun Dec 23, 2007 4:42 pm
There is alot of info on the RB20 swap into a 240sx. I looked into it a little while ago and if you search, i have even found a step by step walk through and even on this site there is a blog about the RB engines and the guys that run this site will switch this chat over there. I have no problem with you asking this even though there is alot of info on it out there but i have a feeling that alot of people are going to post just to yell at you.
First the swap seems pretty easy and I think if you can put an engine in your car you can do the RB20 swap. From what i here, (anyone correct me if im wrong), You can use you KA motor mounts and drive shaft to just drop the engine in but you need a R32 x brace. I know that you need a custom throttle cable. and figure out how to wire the thing up. there are diagrams out there and i know there is a guy on here who will do it for you for a good price. You need a tach meter to adjust your gages. Keep looking there is soooo much out there on this swap, even on this site.
