Shocker »
https://forums.nicoclub.com/shocker-u18595.html
Fri Jan 06, 2006 8:59 am
what your gonna do is mate the transmission and the engine together.. suspend them from a cherry picker, jack the front of your 240 up about 2 feet or so off the ground, i mean way up, have someone pick up the rear part of the transmission as it clears the radiator support, and just walk the motor and transmission together towards the car lowering a bit.. it should slide in like cake.. Now the hardest part is lining up the mounts, so to make this easier, lower the car and the cherry picker together basically putting the 240 back to ground level, get a floor jack under the rear end of the transmission and help raise and lower it to its desired height so that the mounts line up. This is exactly what I did for my motor, and it litterally just poped right in, hardest part was getting the mounts to line up because I didnt have an engine balancer and my chain was too long on one side.. so if you have a balancer use it, it will make this even easier to do.
