rb20 injector question
slideways_240
Car: 1992 nissan 240sx rb20det
can anybody tell me the best way to check my injectors without making a mess in my engine bay and my garage, is there anyway to take the fuelrail out and check them that way.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Do you want to test the O-rings or the Electrical part of the injector?
Do a fuel pressure test and see how long they system holds pressure after the engine is shut off. If it hold pressure for longer than 10 min then the system is good. If not the O-rings need to be replaced.
OHM the injectors directly to check the coil inside the injector.
RustspecS13
Car: '74 260z and '88 300zx turbo
You can test the resistance with a ohm meter, they should be between 9-14ohms I think. They are usually right around 11ohms.
Also you can pull out the cam angle sensor and the fuel pump fuse, and spin the cas by hand and listen for each injector to click.
~Alex
slideways_240
i want to check the spray pattern and the flow of them
Sil240
Car: Nissan S13 "The One Cam Wonder"
take it to an injector servicing place.
They clean and flow them for about $15 to 25 each
Either that or you'll have to rig up an system which probably isn't worth your time.
240z4u
Car: '95 Nissan 240SX
www.witchhunter.com did a great and very fast job for me!
Carl H
^^^ ditto, use them for my injector service after issues with a certian vendor on this forum.
never been dissapointed with witchhunter, gordon is a great guy.
slideways_240
i checked the ohm's and heres what i got, 5 of them range from 13.8-13.9 and one at 14.8-15.0. mayb this one is a problem.
