rb20 in s14: plz help coolant gauge inop, already searched...
daveh93s13
Car: 96 240sx se coupe
im my 96 s14 with an rb20det, i cannot get the coolant temp gauge to read. im almost positive the blu with blk trace wire is the one that i need to use to splice into my auto meter temp gauge. so i did that and it dosnt read, the gauge wont move even after warming up the engine. then there is another blu/blk wire right near the first plug that has the blu/blk wire. when this is spliced in, the gauge max's out even when cold. i replaced the sensor with a brand new unit for a ka24de. PLEASE HELP, its near summer time and i need to know what my car is running at so i dont cause damage. thanks in advance guys!!!
PorkChopExpress
Car: rb kouki
the blue/black is for the cluster temp sensor ,,
daveh93s13
ok im going to try to connect that to the yellow ka f3 plug and see if it works.
----- i connected the yellow ka wire to the blu/blk wire and the gauge is still inop. i also tried connecting the yellow wire to the wire that goes to my autometer temp gauge, nothing there either. what should i try next?thanks alot
Modified by daveh93s13 at 9:15 AM 4/28/2008
daveh93s13
c'mon guys, 43 views and only one reply? can somebody plz help me out.... i need to get the car situated thanks
ripracer
Car: 01 Dodge Ram & 91 s13 hatch
My temp gauge actually just stopped working on me the other day. I ordered a Autometer to replace it and was hoping to figure it out from there.
Sorry can't help ya yet. And I look at the Pinout and didn't see anything for coolant temp or temp signal
daveh93s13
porkchop, so i connected the blu/blk rb wire to yellow ka wire and the gauge is still inop? as i mentioned the sensor was replaced. even if the cluster gauge is inop, i tried using the wire from the autometer gauge and its still inop. you said the blu/blk wire is for the cluster, but is the yellow wire on the f3 connector definatly the correct one to splice into? according to the pinouts i found when i searched it is correct....
daveh93s13
i got the gauge to read, but it warms up extreeemly fast, and stays between 225-250, 250 is max hot on gauge so im wondering if it would go higher? do i have to use the autometer temp sensor for the gauge to read right?
Joe
you cannot use the nissan sender for an autometer gauge.
you must use the autometer sender.
daveh93s13
thanks alot kamin, ill swap out that sensor tomorrow afternoon and see how things are.
