rb20 in s13 charging problems
240daveTX
Car: 2005 Nissan Titan LE
1993 Nissan 240SX Convertible
i cant figure out for the life of me why my alternator isnt charging my battery. if i unplug the battery while the car is running it dies. im ready to drive this car farther away from home than what i have been.
its a auto to manual converted s13 vert. ive been searching but no hope
240daveTX
here is how i have them hooked up
1 battery2 misc plugs by fuse box3 starter4 grounded to chasis5 alternator plugs6 not hooked up7 oil plug
this is the KA harness from my auto KA.
Sil240
Car: Nissan S13 "The One Cam Wonder"
RE-build your alternator or upgrade to the Quest alternator (not a direct bolt in) or buy a used alternator
I have the same problem you do, I went to the junkyard and got a Quest unit for cheap.I haven't put it in yet, but I took it to Autozone right after I left the junkyard and it tested good.
240daveTX
the swap is only a couple of months old. it usually just sits in the garage. its never been driven more than 5 houses down the road.
do you think maybe my motorset came with a bad alternator?
wrgibson
Car: RB Hatch
It's definitely a possibility, RB20s are getting pretty old. If it ends up being bad you should just upgrade to a quest alt.
240daveTX
is the wiring all right at least?
Sil240
With the lower harness you can't hook it up wrong unless you start cutting things.
Looks correct to me.
Ricky @ rawbrokerage sells rebuilt alternators.Check him outHe's a good dude
240daveTX
so today i realize my car starts with no starter relay connected
so i made a little video going over the wiring. any ideas.
im probably gonna pull off my alternator to have it tested if its bad ill just have to do the quest upgrade.
sorry about the music, i didnt realize it was so loud.
