rb20 in jectors
vito
Car: s13 silvia
i have 6 volts on my injectors at all times can someone help tell me why?
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
Bad power supply or grounding issue
vito
Car: s13 silvia
it has a resister in it so the 6 volts is right but it is constant
DriftingisLame
Car: '91 240sx coupe, rb20det
You should always have a constant voltage to the injectors, they are not fired by turning the voltage on and off. They all share common power wires if you havent already figured that out by taking apart the harness..
Most electrical actuators are switched on the ground side, as a signal on the ground side seems to have less voltage spiking.
vito
Car: s13 silvia
i just swaped 2 a rb20 from a sr20 in my s13. we got it motor started and run it for a few min. then i turned it off and it has not ran since.
