rb20 in 89 s13 tach does not work
homesivan11
Car: 1989 Nissan 240sx with a RB20DET swap
i have a rbo20det in an 1989 s13, and the tach doen not work. i have looked around the forum and couldn't find any thing..... is there a way of making the stock s13 cluster work with a rb20 wiring
BoostFab
Car: S13cp, S13fb, S14z
couple options: buy one from lsauto; swap in the rb20's tach in place of the stock;
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
Theres a way to get the sohc tach to work no?
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
No, use DOHC tach or get a SARD STACK (lol). Factory S13 clusters wont work without adjusting the potentiometer inside of it. Its a waste of time unless you're 100 percent lucky and it happens to be 100 percent accurate.
Carl H
i can convert the tach to work much cheaper than ls auto...pop me an email.
ST240
check this out... its for converting SOHC tach to DOHC
http://www.nicoclub.com/articles.php?id=272023
not sure if it works or not... ive also heard of the 10k ohm resistor mod to convert from 4cyl tach to 6cyl tach zerothread?id=341788
might want to look into that too. maybe you do both modifications if you swap from 4 cyl sohc -> 6cyl dohc
ill have this problem to deal with in a few weeks here
Sil240
Car: Nissan S13 "The One Cam Wonder"
Question:Can you use a aftermarket tach with the RB, without a tach adapter???
I have a DEFI Stepper tach that I connected to the wire in the little canister under the hood.And I got not a movement from the tach.The tach works but It didn't budge.
I'm not sure if I lost my tach signal or if I need a tach adapter.
PS. not meaning to steal your thread. But this maybe an option for you.
homesivan11
thanks this helps a lot.... all so can some one tell me at what speed should i change at... so i don't redline...
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
doesnt r32 tach fit and work as well?
teamloco
Car: 1991 Nissan 240sx
Thats what i use skyline 8k and works fine
homesivan11
but the sad thing is that i don't have the r32 cluster...
2d-ink
But if you run a R32 cluster you have to run the RB20det Speed sensor which is driven by a speed cable, so you would have to route that cable into the back of the cluster.. I would just go with a S13 DOHC tach and have Carl H adjust it.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
2d-ink wrote:But if you run a R32 cluster you have to run the RB20det Speed sensor which is driven by a speed cable, so you would have to route that cable into the back of the cluster.. I would just go with a S13 DOHC tach and have Carl H adjust it.
I think ive seen people put the r32 tach in the s13 cluster. Either way though Carl H's way is probably the cleanest looking.
BoostFab
that's what i did on my old car.
homesivan11
i email carl but i got no reply?
Carl H
i replied to your email.check again, it might have gone into the junk folder.
homesivan11
i just go the the tech back and pluged it it and it still does not work.....
Carl H
tach was verified on my own car, check your wiring.it read accurately to 7.5k, so i know it is not the tachometer.
240midohiofan
Car: 240sx fastback
Carl H, i sent you an email regarding the same thing as the OP. Lmk.thanksNick ([email protected])
homesivan11
I got the tach to work, for some reason the wire thats goes to the gauge is messed up.... I clipped off the wire where it plugs up to the gauge then wired another wire from the ecu to the gauge and it works....
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
That is exactly how mine is. Swapping the tach from the skyline cluster to the 240 cluster is not hard at all. It is a direct replacement. hardest part is just pulling the cluster apart, even that is not hard.
The skyline tachs face plate is a little bit smaller than the 240's, light from the clusters backlight shines around the tach but that can be fixed with a bit of ingenuity. Also, you will have to cut the skyline tachs face plate in the clock area in order for the clock to show.
