the_momo »
https://forums.nicoclub.com/the-momo-u29599.html
Sat Oct 14, 2006 1:37 pm
just like the title says. it starts and is smooth at 2k (really high i know) and then it stumbles and dies after about the same amount of time (10-15 sec) i think its like a start up cycle then it dies.
some things1. it has a gm 3 inch maf. there is also a mystery black box controlling it.2. i didnt do the wiring or initial swap. (there are a lot of deamons in the car, but it does start.)3. there isnt a serial number on the ecu.4. there are a lot of open plugs on the harness, but no where for them to go on the motor or chassis.5. the car did run before it was torn apart (i bought it disassembled)6. the ecu has a dial on the back, and lots of japanese.7. the car was run without the iac valve. (throttle was left open slightly..i know ghetto.)
it gets good fuel pressure (around 43psi) and the ignition and timing are functional and correct, respectively. i thought it might be the tps so i pulled them and cleaned the contacts, no change. it has the aftermarket big plenum intake manifold and a q45 tb, has the two connectors (one on the tps and one on a wire lead from the tps).
ive tried things that i could think of, but just wondering if anyone had a similar problem or know what could be the issue. thanks for the input in advance!
