91_ka24de »
https://forums.nicoclub.com/91-ka24de-u119182.html
Wed Nov 12, 2008 4:00 pm
the throttle postion sensor is attached at the throttle body. its like a distributer, you crack loose the 2 bolts and adjust it from left to right which ever sounds better. Or you have blown the TPS. thats what happend with my ka24de. some times it would act fine, and have you notice a loss of power? if so i'd either check the tps. move the tps from left to right if you get no notice in the engines idel than sure enough u need a new one. hope this helps. GL
