rb20 hp questions?
OlyDriftSquad
hey guy`s i just got me an rb20det, and i was wondering what it takes to make some nice hp numbers? 400 ?i was going to add the flowingt3/t4rinectors3 inch full exhaustintake manithrottle bodynice fmicand possibly the 26 stuff ?
and is it really worth puting the 26 internals into a 20 to make it a 24? this is olny what i have herd i dont know if it`s true or not. thank`s guys
OlyDriftSquad
also. were can i get my aftermarket parts for an rb.
xjon
Car: 99XJ, 93 240coupe
Search nazi's will get you! Check out the NICO sponsors, Some of them carry rb parts. Check out rbmotoring.com , phase2motortrend.com, mckinney motorsports.
Congrats on getting the engine. Hope it looks good. take some pics and show us.
OlyDriftSquad
i actually got my clip for 1900 plus tax. =) and looks good will take pics on 10 when i get it in the car =) hope it goes in nice i just converted it to rhd 91 coupe
Sil240
Car: Nissan S13 "The One Cam Wonder"
Where did you get your clip for 1900?????
Porschephile
Car: '98 Maxima
You'll need more than that if you want 400rwhp. If you are talking crank HP, that's a little easier. However, you'll need a metal head gasket and some type of engine/fuel management to properly tune everything. With a t3/t4 and the proper specs to support 400hp, you are going to have to run a lot of boost and probably have a significant amount of lag on an rb20. I say shoot for 300rwhp and you will acheive it fairly easy for much less money.
As far as building an rb24, too much money IMO. From what I've read before, some of the 26 parts do not fit and require machining for proper installation in the rb20 block. You'll probably spend $2-3k+ just for the 26 internals, and quite a bit more if you have a shop do the work. It's a little too involved for most people.
WDRacing
It really depends on how much money your willing to spend. You'll need a set of 550 or better injectors, Some fuel managment, either a new ECU or say an HKS AFR or SAFCII. You'll need to ditch the stock turbo. A nice T3/TO4E in 50 Trim will be nice, not much lag either. I was using NA cams which give you another 8 degree's of duration. They only cost me 50 bucks. The stock head gasket will hold just fine for 400hp. If thats your goal, if you want more buy a metal type. The FMIC is a must. I would also suggest some alcohol injection.
That will get you real close to 400 if you keep adding boost and monitoring knock. If you keep the detonation away you'll be good. Whatever your lacking, simply bolt on a Nitrous Express kit jetted for 50 HP.
Its really not all that difficult.
WD
goofynick6
Car: 1995 S14.5 RB20DET
I have most of those already :D 550's on the way, t3/to4e 50 trim on the way, hybrid FMIC is here, getting an safc2, then a 3" exhaust cutout on the downpipe...I'm aiming for 350whp.
Nick
Phixius
Car: S14 w/RB26 and AW11
think you could fill me in on alcohol injection? WD.
WDRacing
Of course I can...lol. I'm on the way to do some cliff diving, But I'll post some info up when I get back. Or shoot me an email, [email protected]
