Rb20: Hesitating, backfiring, when driving.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Hi, this problem just poped up, when i hit about 2k rpm's and on the car starts to pop and backfire and jerk, i checked all my ic pipe, does this sound like a boost leak?
thanks
rb240det
Car: 1991 240sx Hatchback and 1994 300zx
RB20DETodd wrote:Hi, this problem just poped up, when i hit about 2k rpm's and on the car starts to pop and backfire and jerk, i checked all my ic pipe, does this sound like a boost leak?
thanks
Could be a boost leak. I used a 2" PVC cap, drilled a hole, put a valve stem in it, and hose-clamped it onto the elbow off of my compressor housing. Grab a cheap bike pump and now you have a way to test for boost leaks. Helped me find two that I had (including a leaky MAF). Hope it helps...
Bluefire
Sounds like a maf problem. Check the wiring first and if thats ok then try and get your hands on another maf. My RB25 maf recently died also for no apparent reason.
-Bluefire
RB20DETodd
Bluefire wrote:Sounds like a maf problem. Check the wiring first and if thats ok then try and get your hands on another maf. My RB25 maf recently died also for no apparent reason.
-Bluefire
TY sir found the problem!
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
usually whenever you hit a rev-limit like effect around 2k-3k it involves the maf, good rule of thumb to go buy.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
I would agree with it being the MAF as well, either loose connection or it went bad, i forgot to plug in the MAF on my friends 300zx, and it bucked and backfired, like crazy, i plugged it on, and it drove fine and i went about my business.
Andrew85cm
Car: 89 240sx with RB20det
I don't know about you but if my maf isn't working or is unplugged I notice before even leaving the driveway. I have left it unplugged a number of times.~ANDREW~
s13_drifter
Car: 1989 nissan 240sx rb20 powered hatch, 91 TT Dodge Stealth, 95 nissan beater pick up
unplug your maf and drive your car around if the car runs the same as it did with the maf plugged in then its definetaly your maf, I rewired the maf wiring on my rb20 like 5 times and it didn't help at all turns out my problem wasn't the wiring but was the maf itself used my freinds maf and my car ran perfect before it would randomly get fuel cut and not be able to rev past 2000 rpms.
hope that helps
-Gleb
