rb20 help
tim327
Car: 95 240sx rb20
my rb 20 stops fulling when trying to boost i bought an harness that was setup for ls2 coils and has a resistor pack on it but everything else is stock so could the stock rb20 injectors not be getting the voltage they need and if there is anyone that know a lot about this motors around clarksville tn let me know can haul car to someone to help thanks
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
stock RB20 injectors are high impedance so you don't use a resistor pack with them. Get low impedance injectors or wire the resistors out of the harness.
tim327
Car: 95 240sx rb20
so will they just need to go to 12v when key is turned on or do i need to undo the harness and find the old wire for them thanks for help
