Rb20 Help
91240sx rb20det
Car: 1991 240sx Rb20det
Where is the ckp located on the rb20det???
Thanks
uber95
Car: S14
I won't give you a fish, but here's a fishing pole.http://www.dizons.com/manuals/...n.pdf
themadscientist
ckp? WTF is that?Fish? hmm, that's not a bad idea for lunch.
91240sx rb20det
what else could be wrong i'm not getting spark or fuel yet. Just put in walbro 255 today
Crankshaft posistion sensor
themadscientist
If you mean the cam angle sensor it's the round dodad on the front of your timing cover. Pull it out and spin it with the key in the run position. If you hear your injectors clicking it's working. if not it doesn't mean it's bad, something else could still be wrong.
91240sx rb20det
i don't mean the cam angle sensor but i'll try that out. one more thing do you know where to get a speedo cable???
themadscientist
what chassis is the motor in?
91240sx rb20det
91 s13
themadscientist
the s13 doesn't have a cable, it uses a sensor in the same place the cable went on the transmission when it was in the Skyline. Pop your KA sensor in the spot the RB cable went. Someone who has done the swap please clarify if the speedo will read correctly.
91240sx rb20det
that sucks i sold the old ka. i'll pick one up but will it be off i heard it will be.
themadscientist
so the sensor went with it?
91240sx rb20det
yupp
themadscientist
sux dude. search the forum for the sensor and make sure the KA one is the right ratio to provide a correct speed to your meter and go junkyard hopping.
