RB20 guys!
90240sxca18
Car: 1990 nissan 240sx ca18det
Post up your specs, power results ect ect.
Im just interested to see how much power people have gotten out of the 20 on here. I am a 20 owner myself and in time due I want to build the motor and throw a 25 trans on it and shoot for the 450whp zone, but I wanna know who makes around that, or more and what your setup is.
Also, anyone that just isnt stock post up. Im interested in any setup that is 300whp or more. Lets see what yall have done!
Wongger
zer...esult
check that out. Few good set ups
Carl H
doable...but might spend some coin to do so.
the combo i have that worked for me is as follows:rb20det - std bore/stroketomei 260/8.9 procamsgt30rz32 maf720cc injectors
18psi got me to around 387whp, i'd imagine 450 is doable with about 4 or 5 more psi out of the 30r.
90240sxca18
Thanks!
What manifold are you using?
What about on the intake side? manifold?
You might have posted it but what are you using for tuning?
And lastly, what pistons and rods are you using?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Check the link above.Scroll down near the end, you'll see his whole setup.
Along with a couple others
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Yeah check the link mines in there too 398 so far at 16.8 psi.
Pantaro
Car: 1992 nissan 240sx
nice numbers from rb20's might just have to purchase one at the end of the month.....
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
I ran a 13.89 @ 99.51 with my rb20 @ 12 psi if that helps. Had drag radials tho.
If you want my advice tho man, go with a bigger engine. More expensive, but trust me, the rb20 leaves you wanting more pretty quickly.
Pantaro
thx for the advice,i did find a sweet deal on the rb25 so i prolly will go bigger
