rb20 gts4 engine swap question
ibzbro
Car: paintball, and cars
i have a awd drive rb20 and i need to know what to change. here are things i know, the oil pan, transmission, crossmember, engine to crossmember brackets, transmission member. Is there anything that i am missing? and also when i pulled the transmission there was a NISMO flywheel, can i use it?
themadscientist
You will need a 2WD Skyline oil pan and the crossmember. Regarding the flywheel pat yourself on the back it will work fine.
