ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Mon Feb 14, 2011 2:04 pm
It can also be an external pulley causing the problems. For example, the AC compressor clutch can lock up or drag causing the noise, power steering pump, alternator, water pump, or even timing belt tensioner/idler pullies. Provided that your oil and filter are still clean and free of noticable shavings, then the problem will most likely be something external.
