Rb20 Fuel Pressure
ddtrav2
Car: 91 240sx
First off I did Search but came up with nothing so it's probably not possible. Well, I'm pressed on time and I need a Fuel Pressure regulator, I don't have time to wait on one to be shipped so I was wondering if a fuel Pressure regulator from any other Nissan vehicle will work with a rb20. So far I found a 96 Nissan Altima Fuel Pressure Regulator that COULD work. Any input or ideas anyone?
uber95
Car: S14
You need a rising rate FP regulator, most are 1:1. Why would you half-a$$ it with an N/A application unit and risk your motor? Spend the $ and time to get a Nismo Type-A regulator that you can adjust and has the proper rate.
Carl H
ka regulator will work just fine.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Yeah, any vacuum reference fuel pressure regulator will be a 1:1 rate.
ddtrav2
Car: 91 240sx
Thanks everybody for your input
