SeVa-S13 »
https://forums.nicoclub.com/seva-s13-u4555.html
Wed Sep 01, 2004 5:48 pm
Well I've got my fuel pump turning on/off problem fixed. My ECU is borked somehow and another problem I had is that my SOHC FSM's wiring diagram for the fuel pump elay was WRONG but I digress.
The problem of my car running to rich remains. I can start it up (with a working ECU) but it runs so rich the exhaust is thick with black, unburnt fuel and dies quickly if I don't continually rev it. I have checked connections for my MAFS, O2, Head Temp, CAS and pretty much anything else I could see. All my IC piping is tight and I am aware of no vaccuum leaks. ECU shoots 55 all day.
My question is this, did some (early) RB20's come without a Fuel Dampener (the regulator-type thingy at the rear of the fuel rear connected to the fuel feed line)? Mine lacks one and it looks completely stock but Justin's (Project240) later year (no RB20 stamped on the front cover) RB20 has this dampener doo-hickie and his has no problems like this. I am runnign my stock FPR at the moment which reads about 40psi which while a bit over what it should be, shouldn't be enough to kill the engine like it is. We drove Justin's RB with stock FPR and it ran fine. But just as security, I borrowed his new, tuned-for-his-Rb20 Nismo FPR to use on my car but only to suffer the same results.
So in closing, if anyone can lend some ideas as to why my freakin' engine is dying like this or where I can buy an RB20 ECU (or how to fix mine), I'd be very grateful.
Thanks-Blake
