Vkoslak »
https://forums.nicoclub.com/vkoslak-u5069.html
Wed Feb 10, 2010 7:54 pm
I was tracking my rb20det. I made it through 4 events. If I hadn't tracked it, I would still be able to drive it.
I also had an undersized FMIC, small electric fans, and the oil pump the motor came with. No oil-cooler, minimal heat shielding, and a crappy undertray all while pushing a hks gt2530 turbo at 17psi (309rwhp). My last track session, I was out running very quick modified 300zxs on the straights and could out corner them too, but I was only able to do 1 or 2 laps at full throttle before I had to back off due to heat issues and everyone I passed caught back up.
If you cheap out like I did, you will have results about the same as I did.
The rebuild is getting a rb26, n1 pump with reimax gears, moving the radiator so I can run a clutch fan with shroud, r32 gtr intercooler, some form of oil cooler, and an accusump setup. The 26 is currently on an engine stand so I can change all the gaskets, including the head gasket, and put in new bearings and bolts.
I think a rb20 can be run on the track, just don't skimp on oil pump, intercooler, oil cooler, fans, ducting, and you should do something like an accusump to prevent oil-starvation. Going over 7k rpm is not a great idea either.
Of course, the same things could be said for a turbo ka setup if you want it to last.
I've seen NA KA 240sx at the track doing lap after lap, hpde after hpde with no issues. If you're on a budget, stay NA and just take as much out of the car as possible for track day.
I've thought about gutting an s12 200sx and putting in a ka24de to make my track slut.
