Cloud7659 »
https://forums.nicoclub.com/cloud7659-u31524.html
Tue Aug 23, 2005 5:37 am
BUMP. Ok I need some help, my injectors are not firing, I have fuel in the rails but I have no fire signal in the injectors. The ecu is not sending them ground. How can I fix this or check what is wrong?
Also, nearing the firewall, coming out of the efi harness there is a little plug with two blue wires that have ground on them (when I test it). They are cut, I don't know if this has anything to do with anything, im just throwing it out there.
