Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Sat Mar 20, 2010 2:50 am
you need to get a tach that works/reads correctly in the car...else you're flying blind.you also have not mentioned if you have a wideband in the car from above i am going to assume no, so i would guess with the 550cc injectors it is running silly rich.RB series engines run VERY well when rich, unlike other engines which tend to run like crap.The short answer is that you're running so silly rich that while it runs and drives AFRS while driving off boost are probably in the 12's and dive past the 10's when you get into boost due to the 1:1 nature of the stock fpr.you should not be driving around without some form of management on this setup as you're only asking for engine damage to occur.
fitting an rb20 ecu is not hard, add 1 wire and swap 2.downside is you loose vtc but for the money saved instead of going aem or pfc i'd drop a set of rb20 spec cams into the engine with some cam gears and kill off vtc...its lame at high hp/high rpm anyways.
the other option is a z32 ecu...not a bad ecu but several wires need to be swapped and support for only one knock sensor.people will tell you to gang the two knock sensors together but this is quick and dirty to make it work.
yet another option is the VE30DE maxima ecu that they only made for 2 years...it is a direct dropin for the rb25 but requires the use of a daughterboard.JWT can tune this ecu or nistune has support...been a while since i looked into it tbh.
