RB20 ECU
apex_7
Car: 240sx
Well, I burned up my second ECU last night... my car hasn't been running in almost two years now. Anyway, I was wondering if anyone had one laying around that I could buy. Thanks,[email protected]
foCk
I've got one but it needs a new pad for where the eeprom goes into the board
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
apex_7 wrote:Well, I burned up my second ECU last night... my car hasn't been running in almost two years now. Anyway, I was wondering if anyone had one laying around that I could buy. Thanks,[email protected]
Why don't you try and fix the problem 1st before you buy another ecu? What killed it? did you wire it wrong?
apex_7
Car: 240sx
I'm trying to figure out what made it smoke right now w/ the old one, but in the meantime I need to source another one. Basically, I replaced the waterpump and set my base timing and turned the key but the fuel pump didn't come on. Then I smelled something and turned the key off and the ECU kept smoking. It wasn't a lot of smoke, but just enough to make that burnt electronics smell. Leading up to this, I did some rewiring to clean up the stuff that wasn't in use and put some of it in the fenderwell area and somehow messed something up. I'm going to have a friend w/ an RB help me out tonight to see if I can't identify the problem. I still need an ECU though. Here's a couple shots of the wiring (not cleaned up yet) so that maybe someone can spot something wrong.
OKCA18DET
nice suspension..what kind of job do you have?
