rb20 ecu and harness on rb25?????
91drftr
Car: nissan 240sx
alright so ive seaeched and havent really found an answer
i currently have an rb20 swap on my car and well i just got a deal on an rb25 but it didnt come with the wire harness ecu or maf
so i wanted to know if it was possible to run the rb20 ecu and harness along with the maf on the rb25
can anyone help me out on this?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
You can use the MAF on the 25 as they are the same between the two engines.
The ECU can be chipped/rom tuned for a RB25.
The harness will be a mess if even possible to get everything sorted to work.
If you end up needing a RB25 harness and ECU I have them in stock.
Hope that helps.
91drftr
Car: nissan 240sx
Coolwhip wrote:You can use the MAF on the 25 as they are the same between the two engines.
Hope that helps.
hey man if i dicide to get the ecu and wire harness from u how much will that run me ?
