Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Fri Dec 17, 2004 1:02 pm
just thought i would share a few diffrences ive noticed between old rb20's (rb20 on timing cover) and new ones (blank timing cover).ive got a 93 rb20det which has no rb20 on the timing cover and came with grey faced gauges.the turbo on the "new" rb20 is indeed ball bearing as the banjo bolt i pulled out of the block for the oil supply line had a restrictor built into it.wiring the 2 seems to be the same over all but the gauge cluster wiring is diffrent between the 2 and some of the instrumentation wiring seems to be diffrent as well.there are a few more diffrences between the 2 but i cant remember them, so these are the few that stuck out in my head.
