the_momo »
https://forums.nicoclub.com/the-momo-u29599.html
Mon Jan 08, 2007 12:59 pm
you arent getting sufficient air into the engine to let it idle correctly. more than likely your idle isnt set properly, but to see if its something to do with what i mentioned, crack your throttle open while you start it. search how to set idle properly, thatll help a lot too..
also, check your maf wiring and maf itself, that was my issue (had interference on maf signal) unplug maf and see if it starts. if it does, you have a bad maf or bad maf wiring. there you go. good luck!
