mrbrightside »
https://forums.nicoclub.com/mrbrightside-u30491.html
Wed Jul 13, 2005 11:53 pm
Well i replaced the sparkplugs and it runs a whole lot better. it isnt as powerful as it should be and it runs like a dog, but it is driveable under full throttle. i did a head gasket test on it and the results were negative, thank god for that, i alsodid a compression test and each cylinder had roughly 135 psi of comp (i think thats good) I had a mechanic look at it quickly, that plug was just a plug for hicas (has no effect on 4ws, just controls the hicas light in the cluster) anyway the mechanic told me my car was only running on 5 cylinders and that it was boosting fine. He also said it was most likely a coil. Now I disconnected each individual coil one at a time and every coil when i disconnected it seemed to make a difference (ie the car seemed to drop a cylinder)! I am completely lost to wat the problem might be??? I am a mechanic myself ( 2nd year apprentice) Does anyone know wat the problem might be, all suggestions welcome... Could be ignition timing? The engine i purchased second hand came with the module on the front of the engine (the circular thing on the top cover) however i had to use the module that came with the original engine as the second hand engine had a different shape plug in it. Could this be the problem? Both modules look exactly the same except for the shape of the plug (one is rectangular, the other is rectangular but with rounded corners). It is turning into a s**t fight and i am now starting to regret buying the car I have put many many hours into this beast but nothing seems to be working for me. Maybe its about time i see an expert and let them fix it. PLEASE HELP
