RB20 dash cluster wiring
bloodspread
Car: 1989 240sx fastback and a 2009 Aveo
edit: new problem, I was able to connect the consult port but the car sounds like its misfiring and its running really rich now, I don't remember having this problem before I started wiring the dash and everything that I cut went to a plug already so I dont know what the problem would be any help on this would be great too. thank you for your time.
video of the problem
im trying to wire in my tach and other dash cluster connections but I cant find some wires, I see no yellow/ blue as indicated on many of the swap guides that have been posted on nico and when I look at pin seven there is a brown wire instead of the yellow/ blue this has been a re occurring problem and is my only set back, the car starts and runs fine I just haven't had the time to wire the dash until now. im having the same problem when Im trying to wire in the consult obd1 port, some of the wire colors are just not there pin 7
yellow/ red leads to pin 20 I thought it was tach signal because of the plug it was on, but found out it was not after I unwrapped the harness
any help would be great, and there is a possibility that I am an idiot and cant read directions for s***
Modified by bloodspread at 6:39 PM 10/28/2009
Modified by bloodspread at 10:16 PM 10/28/2009
Modified by bloodspread at 10:17 PM 10/28/2009
Modified by bloodspread at 1:58 PM 10/30/2009
bloodspread
I think that I may have been looking at the ecu plug the wrong way plug 7 appears to be a yellow/ red on my harness and I cant find check engine red/ white and I still dont know if any of this works.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
http://www.apexi-usa.com/content/pdf6119.pdf Look for the N4-B diagram. It says its the 4th going left from the bolt on the top. This is looking at the plug from behind where u bolt it down.
bloodspread
hooked up all the right ones, and still no tach is there any other Ideas of what could be wrong? I also hooked up the obd1 port and after I install all the programs on my computer Im going to check if that works.
bloodspread
nope no luck with obd1 consult and the engine runs a little rough now, got to go back over my wiring and see where I f***ed up
bloodspread
consult works dont know about the dash yet
bloodspread
new question on original post
Race_Breed_2.0
Car: 90' 240sx Hatch, RB20DET Swap
It is a yellow red, I believe carl H has a write up in the rb20swap guide for the cluster, thats what i used and mine works flawlessly, it is also refered to in rb collected data, as well as a quality pin out diagram, Hope this helps, as for the misfire could be many things but sounds like u spiced into an injector wire on the harness to the ecu.
