RB20 CYLINDER HEAD BOLTS ?
180boy
Car: 89 240sx
Can someone tell me what the 3 bolts are for that are in the valley near the spark plugs ? Since the FSM calls for 14 headbolts and those would make 17, I'm confused? thanks to all that reply
mello88
Car: s13
By chance are you referring to the bolts that hold the coil pack brackets down?
180boy
Car: 89 240sx
No, these are the 3 10mm hex hd bolts that look exactly like the other 14 head bolts.there is 1 closer to the front of the engine and the other 2 are toward the rear, down as low as the spark plug holes.I'm not sure if i need to remove these since the FSM does not mention them , thanks
Carl H
those are for the water gallerys, dont touch.
180boy
Car: 89 240sx
I took 1 out should I seal it when putting it back ? torque? thanks Carl
Carl H
use a little teflon paste and torque till nice and snug, its pipe thread.
gawdzilla
Car: none
ha, did that too back in the day. put it back good and it'll be fine.
themadscientist
Mine are always seized up and strip when I try to remove them.
180boy
Car: 89 240sx
Thanks guys, I put permatex paste on the 1 plug I took out and made it tight.
Suicide.Veteran
Car: 93 Nissan 240sx
LYKE JDM TYTE????
